39-in-1 board stuck in test mode
Question from Kristen: Hello! I was given a newer generation Ms. Pac-Man cocktail cabinet with a 39-in-1 board installed. There is a blue SW3 on the board that has little toggles labelled 1-4. In what position should those be? It seems the game is stuck in test mode. For clarity, I have taken the CRT out. Someone dropped the cabinet and it is broken. I am replacing with an LCD which is working fine! Thanks! Any assistance would be appreciated! Thanks again! Kristen
Response from Jonathan: Kristen,
Here’s the manual a 60-in-1 board that tells what each of the dip switches do on the board (see page 2): https://www.hollandcomputers.com/data/Images_Additional/arcade%20game%20parts/60-in-1_icade_classic_arcade_manual_online.pdf
The 39-in-1 board that you have is just an earlier version of the 60-in-1 and I’m pretty sure both boards use the same dip switch settings. If the game is stuck in test mode it’s either because dip switch 4 is in the ON position or that the test mode button has been wired up and is being depressed at start up.
