009A2854-001
Question from Chris: Hello, I’m currently in need of a 009A2854-001 width coil for a Wells Gardner 19K7206 monitor. I have a Vigilante cabinet that is playing blind. When I got it open, the first thing I noticed was the width coil, it had melted. From what I understand, this particular width coil is no longer available. Is there another coil I can use instead and/or modify? Best regards, Chris
Response from Jonathan: Chris,
Not sure about what would be a compatible replacement width coil for this particular monitor. You might try contacting Chad at arcadecup.com to see if he has something that would be compatible for this monitor. You could also try Wells Gardner technical support to see if they know of a compatible coil for this monitor as well. Hope that helps.
