13″” monitor problem
Question from Rob: Hi there! I have a monitor in a cocktail cab that used to be a “Black Tiger”. I think the chassis is a 13″ electrohome. You may be able to make out the image burn in the pictures. Now I have it hooked up to a 60-in-1 and it works ok except that it has a “curl” on the right side. You can see it best on the test screen. I’ve adjusted all the pots and convergence rings and have been able to sharpen up the picture, but the curl is still there. I am including some pics of the yoke and the chassis. What do you think? I have a good degree of competence with electronics, but not much experience with vacuum tube displays.
Thanks, and by the way, I love your podcast! It helps keep my brain engaged while driving, and helps me fall asleep at night too!!!
Rob
