2005 Golden Tee
Question from Mathew: I’m hoping you might be able to help me out – seems like you really know a thing or two about video arcade games.
I purchased a 2005 Golden Tee arcade game and it was working perfectly before I transported it back to my home. When I got home and plugged it in, the screen displays a message, “No Signal” in varying colors. I have checked all the cords and everything appears to be connected…I have no idea what to do!
Thank you so much for your time,
Mathew
Response from Jonathan: Matt,
There are usually two different things that can cause this issue. The first is that there’s a problem with the cable or wiring coming from the board to the monitor. Since it sounds like you’ve already checked this, it’s probably more related to the board not getting the correct power and as such is not putting out a picture to the arcade monitor. We would recommend checking your power supply to make sure it is getting the correct voltage. Please see our post on Checking And Replacing A Power Supply for more information and let us know if we can assist you further.
We have also featured your question on episode 18 of our Q&A podcast. Please listen to it for more of our thoughts on your question. Thank you for your question and keep us updated on your progress.
