Arcade game
Question from Justin: I have a shooting arcade game called MECHANIZED ATTACK made by SNK the issue is the guns dont shake like they should when you fire (no force feedback), i tested the solenoids and the diods on the solenoids in the guns and they test good, so my friend thinks the io board which has the gun imputs on it is the issue, can you give me your opinion on this and where can i get a new io board or can the one i have be fixed? I live in Hebron Ohio
Thanks,
Justin
Jonathan Leung Jonathan Leung ⋅ Staff April 2, 2013
Response from Jonathan: Justin,
It does sound like you might have a problem with your I/O board. You might be able to fix it by touching up the solder points. You could also trace the voltages around the board to see which electronic parts need to be replaced. If you don’t want to bother fixing the board yourself, it looks like there’s a guy on eBay that has one for sale. Here’s the link: http://www.ebay.com/itm/SNK-GUN-I-O-arcade-game-pcb-board-part-C28-/151007895234?pt=LH_DefaultDomain_0&hash=item2328c59ec2.
