Arcade monitor
Question: Hey, i just picked up a virtua fighter 2 cab took about a hour drive and then rumbled from drive way into my house. Could that affect the monitor? I asked because i turned the game on today cold start, looked beautiful then after 5 minutes it got blurry and horizontal lines running through it. also washed out color. What’s weird is it looks good then goes bad. Any ideas?
Jonathan Leung Jonathan Leung ⋅ Staff August 16, 2012
Response from Jonathan: Yes, that could affect the monitor but I don’t think that’s the case here. Based on your symptoms, it sounds like you might have some flyback issues. You could try touching up the solder on it to see if it helps but it might be time to just replace it. Check out our post on Troubleshooting Monitors With Michael for more information about flybacks. Thank you for your question and good luck with your repair.
