Asteroids Deluxe
Question from Kevin: Hey Guys –
You’ve helped me in the past with a problem Ms. Pacman and you were spot on so I am coming back for advice on an Asteroids Deluxe. Everything plays great and looks great, the only issue I have is that it doesn’t save the top three high scores like its supposed to. Have you come across this problem before? I thought maybe there is a dip switch setting or something but I have’t seen anything. I haven’t had the machine long and its always done this. I tried erasing the scores through the test screen and it says its erasing but it never records any more. I suppose I could add a high score kit as a fix but I thought I’d keep it original. Any thoughts would be appreciated.
Thanks for all you guys do!!
Kevin from Woodinville, Washington
