atari digdug
Question from Jerry: Hey guys i know u guys r pros and im new to this i just got a digdug arcade machine and it worked perfect at where i bought it….i moved it just 1 block and now i get the screen in my pic…the scenes seem to change still but only with lines as shown… got any ideas…thanks…jerry
Response from Jonathan: Jerry,
Looks like some of your monitor wiring or harness may have shifted during the move. Check the harness that connects to the board to make sure you are getting a good connection. You will also need to check the wires that are running from your harness to the monitor. It looks like your sync wire in particular could be the culprit. If you’re not sure which one is the sync wire, you might try to find a Dig Dug manual online. Hope that helps.
