B+ voltage on a Kortek KTX 26 and a Sanwa PW-1545
Question from Jeremy: I was wanting to know how to check the B+ on a Kortek KTX 26 chassis and also on a Sanwa PW-1545 chassis.
Response from Jonathan: Jeremy,
Unfortunately I’m not very familiar with either of these monitors. With that said, it looks like you can get the B+ on the Kortek KTX 26 by checking pin 8 on the flyback transformer according to page 13 of the manual. On the Sanwa, try checking the resistor at location R804 and the fuse at location F802. I’ve seen it mentioned that these two parts are at the end of the power supply section of the chassis which would make them a good location to check for the B+ voltage. Hope that helps.
