BBH Sportsman’s paradise
Question from Daniel: Hi. I’ve got a Big Buck Hunter Sportsman’s Paradise and it’s playing blind. I did a cap kit and now I have neck glow as before I didn’t but still no pic at all not even a flash or even a change. It just looks like screen is off. Any ideas you could give me before I have no choice but to get a tech in and it means $$$$$$$. Any ideas would help (in layman’s terms please). Thanks, Daniel
Response from Jonathan: Daniel,
Sounds like you’ve gotten off to a good start on this repair. At this point, we would probably try turning the brightness potentiometers up on both the flyback and the adjustment board to see if we get a bright, white screen. If you try this and the screen does not turn bright white then you could still have some problems in the power supply section of your monitor chassis. At this point, we recommend checking out our post on Troubleshooting Games That Are Playing Blind for additional repair information. You might also check out our post on Checking Diodes On An Arcade Monitor as this could be related to your issue as well.
Please keep in mind that every monitor chassis brand and model is different so let us know what you have in your cabinet if you need additional help. Please visit the What’s My Monitor page on Bob Roberts site if you need help identifying your monitor chassis.
