Big Buck World gun issue
Question from Brandon: Hi there, I have a Big Buck World 27 inch cabinet game. The guns have started to not register on the left side or bottom inch or so of the screen. With it being both guns displaying the same behavior, is this a screen issue? Thank you in advance for any advice you have. Brandon
Response from Jonathan: Brandon,
Yes, this could be a screen issue. It’s probably a good idea to tweak the contrast and brightness on your arcade monitor just a bit to see if it helps the problem. This issue could also be related to the gun calibration so you might try to recalibrate and see if that helps as well. Make sure you check out our post on Troubleshooting Light Gun Issues as it has more tips like these that should help you out with your problem.
