Cabinet style 60-in-1 question
Question from Allen: Hello, I finally purchased myself a cabinet style 60-in-1 game. It operates great but I cannot get the screen to flip from one player to the next. I have the manual which discusses dip switches but I cannot find them anywhere! Any suggestions on resources? Thanks and Merry Christmas. Allen
Response from Jonathan: Allen,
Some 60-in-1 boards do not have the hard dip switches that are discussed in the manual. On this version of the board, the only way to set the Cabinet setting is through the test mode button. Sometimes there will be a test mode button on the board itself. If not, you will need to wire one up. According to the manual, the test mode button should be wired to pin 15 on the parts side of the JAMMA harness connected to the board. If you need some help with this process, you might check out some of our posts and videos discussing the JAMMA standard. They should get you going in the right direction.
Hope that helps. Thank you for your question and we hope you have a Merry Christmas.
