can’t get into arcade console
Question: I have a CAPCOM arcade BY DYNAMO MODEL #020805600 that plays many games. Now it doesn’t work and I hear this clicking noise coming from the unit. I can’t seem to figure out how to get inside to check the power supply. It doesn’t show any screws on the back of the cabinet. Can you tell me how to get inside the thing. Thanks.
Response from Jonathan: Some Dynamo cabinet models allow you to access the components from the front. You might try unlatching the control panel as it may be located on a drawer that you can pull out that has the PCB, power supply and isolation transformer on it. Some of these cabinets even have a hinge that allows the monitor to tilt forward so you can work on it. Of course, all of this depends on the type of cabinet you have. Check out our post on Opening An Arcade Cabinet for more information on how to unlatch the control panel.
