centipede arcade problem (blue screen)
Question from Brad: Hello guys
hoping you can help me out here, at least give me some direction.
I have a centipede game that when you power it up it comes on with a solid blue screen (no sound) if I remember correctly it didnt make sound untill you put a quarter in. Could you (in laymens terms) maybe give me an order of things to check, any help would be appreciated.
I also have a joust game that powers up and gives me ram 13 error after its checks and when the screen comes on it has a dotted line that runs down the right side of the moniter, is this a chip?
any help on these would be greatly appreciated
Thanks Brad
Response from Tim: Hey Brad sounds like you a have a board issue or more than likely your AR board is bad. There are test points on that board you can check to see if the voltage is good.
Here is a good article (even though its dig dug) that can help you
http://everything2.com/title/Atari+audio+regulator+board
Only thing that would make it your monitor is if the game coined up and played blind.
There are a couple different AR boards and here is a pic of what they look like
http://www.google.com/imgres?q=Atari+AR+board&hl=en&biw=1016&bih=621&gbv=2&tbm=isch&tbnid=_cvme9pYJcblLM:&imgrefurl=http://bitslicer.tripod.com/ar_sense_mod.htm&docid=Cfpvewmcsfzf4M&w=957&h=571&ei=LxZ5TqSFBMugtge5xqgB&zoom=1&iact=hc&vpx=130&vpy=334&dur=3369&hovh=173&hovw=291&tx=168&ty=154&page=1&tbnh=109&tbnw=182&start=0&ndsp=14&ved=1t:429,r:9,s:0
Like the article says you can get the AR repair kit from Bob Roberts at http://www.therealbobroberts.net
Hope that helps
