chassis question
Question from Paul: Hi
I recently purchased a ms-pacman arcade game. The chassis in the machine is a wells gardner 4900. It only has three adjustment pots on the lower chassis. Would a replacement chassis with four adjustment pots be suitable for a replacement?They look almost exactly the same except for the pots. I believe the three pot version is an earlier style.
Any feedback would be very thankful
all the best
Paul
Response from Jonathan: Paul,
Yes, I believe you are correct. I have seen several variations of the WG 4900 chassis and I believe they are all compatible with each other. Thank you for your question and good luck with your repair.
