DEFENDER COCKTAIL LIGHTING
Question from Lee: First off thank you guys so much for your expertise. I have a Defender cocktail machine which works great, but no lights. The 1 and 2 player lights dont work and no control lights either. Where to start? Im a newbee, but im trying. Ive changed all bulbs before. Could it be a fuse? Bad Wiring? It used to light up. Please help!!!! Thank you!!!
Response from Tim: Your very welcome. Your lights are either 5vdc or 12vdc so its possible it could be a fuse or bad wiring. Check your ground wire in particular especially if it used to light up. Also make sure you put the right bulbs in there.
