discharging monitor
Question from Jason: Hi there. Love your videos. I just found an old DK machine in a barn and am about to start restoring it. (so I will have a ton of questions Smile with tongue out) As far a making the “discharging toolâ€ with the lamp cord. Do I need a certain gage? Do I just cut off the plug end and then attach aligator clip? As this will be my first monitor discharging I want to do it right obviously!!!
Thanks again,
Jason
Jonathan Leung Jonathan Leung Staff June 22, 2011
We usually don’t specify a gauge just something the equivalent to a lamp cord. Most of the time we use an indoor extension cord, cut off the ends, strip the wires and solder the alligator clips to those wires. If you’re not quite confident in your skills, you can go to our friend Bob Roberts site and purchase one from him. Here’s the page with the information: http://www.therealbobroberts.net/safeback1.html. You will have to send him an email to order. The ones he makes are pretty nice and relatively cheap. He also has a page that tells you how to make his version. Hope that helps.
Also, it usually takes us a bit longer to reply to emails but I saw your email tonight and thought I would go ahead and answer it. Just please keep that in mind if it takes us a while to get back to you in the future. Have a great night.
Response from Tim: No certain gauge but the heavier the better thus the standard lamp cord works just fine. Yes cut the plug in off and strip the wires and put an aligator clip on the end.
good luck
