Donkey Kong Arcade Help
Question from Brian: Hello,
My name is Brian. I have recently purchased my 1st arcade game, Donkey Kong. The game doesn’t work, so I have been trying to fugure out what is wrong with it. I have watched almost every video that you have on you tube and your website. Thank you for all the knowledge you have shared with me. I have learned a lot.
My system will not turn on. No sound or anything. When I plug it in, I here the power supply hum like it is getting power, also my marquee sign works. I believe my power supply is good…could be wrong, but I think it is ok. I seem to think the problem is in the monitor. I have done research and was told that since I have no sound or video the monitor may be the problem.
I have safely removed the monior and seperated the monitor from the control board chassis. There was a blown fuse on the board, but i have already tried replacing it…but it did not fix the issue. I know something caused the fuse to blow, but I have been unable to determine the cause. I would like to get this fixed and serviced. Please share any advice you can with me.
Can you help me with this, or can you give me a little more guidance.
Thank you
Brian
Tim Peterson Tim Peterson Staff March 5, 2011
Response from Tim: Not sure if your power supply is good until you read the voltages coming to your main board, but since there was a bad fuse on your monitor it is suspect
There is a flow chart that may help you out if you do a search for it.
