Drilling locks on mega touch counter top machine
Question from Steve: Good evening. I came across your video about drilling locks, but have a question. The machine I picked up has regular key locks, but also the stubby round locks, maybe they are called tubular locks? Can they be drilled out as well?
Thank you
Steve
Response from Jonathan: Steve,
Tubular locks can be drilled out as well. With that said, you will need to use a pretty big drill bit in order to get through the lock and break in. If you drill through the lock and the door still doesn’t open, try a bigger drill bit. Keep repeating this process till the door finally opens.
