faulty monitor
Question from Barry: Hi i have a hantrex polo monitor, the picture has lost about 4″ width either side, if you try and adjust the h amp the screen turns blue and the monitor switches its self off. the monitor has worked fine up to now and the problem happened over night.
Thanks
Barry
Response from Tim: Your vertical IC is going out or the caps in that area. Good time to do a cap kit and go from there
