Fwd: Super Pacman 60 in 1 upgrade question
Question from Larry: Good morning,
I am currently upgrading my super pacman with this kit. The picture below shows my the wires coming from my Super Pacman and their connection to the corresponding video wires from the jamma harness. When I turn on the machine…the picture is distorted and seems to loop up and down. Can you help me troubleshoot the picture problem? Do you have a contact? Thank you.
Response from Jonathan: Larry,
Usually a problem like what you are describing can be fixed by adjusting the horizontal and vertical hold adjustments on your monitor. Check out our post on Adjusting An Arcade Monitor for more information.
You might also be having a sync issue. Look over these links from Bob Roberts on sync. The second link is only related if you have an Electrohome G07 monitor.
A Quick Look At Sync’ing – http://www.therealbobroberts.net/sync.html
A Couple G07 Notes – http://www.therealbobroberts.net/g07notes.html
