Galaga to Jamma Question Monitor hookup
Question from Bill: Hello. A friend of mine and I have spent most of the weekend working in my hot garage on this labor of love. I am adding a JAMMA QB 60-in-1 board to my Galaga cabinet. I am saving all the stock components, control panel etc. The Galaga seems to have a Wells Gardner K4903 monitor. With the old Galaga board the monitor will power up but displayed a white screen with garbage. There is a power switch that ran to the old power supply board and to the monitor. The power cord for example was on the old power board. We took the old power supply board out of the equation and ran the power directly to the switch and to the board and monitor. We installed the new JAMMA board and wiring harness. We connected the video pinouts and the composite sync pin out to the monitor. When powering up, the board boots and we get sound but the monitor will not power up. The monitor has a tag mentioning an insolation transformer. Could that be our problem? We are stuck and wondering if there are any other connectors to the monitor that we should be using. There is a molex connector on the Jamma board and a couple of other connectors etc that we are not using. Thanks and love the videos and the site. Will be checking out the podcast soon. Please reply all, my buddy is cc’d on this email and is the brains behind this operation. Kind Regards, Bill
Response from Jonathan: Bill,
Yep, this is probably your issue. Older monitors such as the Wells Gardner K4903 require the power they receive to go through an isolation transformer. The isolation transformer looks like a big brick in the bottom of the cabinet and usually has an AC input (usually 2 wires coming in the bottom of it) and output (usually 2 wires coming from the top of it). Our friend Bob Roberts has a great article on his web site that discusses transformers if you would like more information on what they do. Here’s a link: http://www.therealbobroberts.net/xformer.html
With that said, you probably blew some diodes on the monitor chassis (if you did in fact hook the power up to it directly from the wall). Check out the diodes in locations D501-504 and replace as needed. Hopefully no other parts blew on your monitor chassis but definitely want to start with the diodes first and see if that solves your issue. Make sure that you hook the isolation transformer back up before trying to power on the monitor again or else you’ll have to repeat the diode replacement process.
Also, highly recommend spending some quality time with our blog posts, videos and podcasts. In fact, we actually have a post where we discuss this exact problem. Check out Checking Diodes On An Arcade Monitor for more information on the process I’ve described above. Keep in mind we also have DVDs for sale that have additional videos that might also help you out. You can purchase them from our online store at http://www.arcaderepairtips.com/store/.
