game boots up but wont load
Question from Andrew: hi, i just bought an arcade machine. i transported it home, and turned it on ad everything worked fine. the next day i got up turned it on, and it went to the normal boot screen ( black screen with a bunch of white writing) then it went the normal loading screen ( a color screen for the game said ” game loading) but then the screen shut off started back at the beginning.
it did this dozen of times, booting up and everything work right and then getting to the loading screen where it started all over again, as if the power kept being turned on and off.
im wondering if there is a certain wire or switch that might have come loose, the only problem im not sure which wire would effect the “loading screen” of the game. and im fairly confident its not a bigger problem because it is a pretty new and reliable machine.
i can send some pictures if you think it might help.
Thanks so much
Andrew
