Response from Jonathan: Rick,
First thing we recommend checking anytime we get resetting problems like this is the power supply. If the board is not getting the correct voltage then it might not have enough power to start the board up properly. Check out our post on Checking And Replacing A Power Supply for more information.
Once you have verified that the board is getting the correct voltage, you might try inspecting the arcade board itself. Check out our post on Inspecting An Arcade Board for some steps you can take that might help you get your board working again. Just a quick tip: if you have any other JAMMA game boards, you might try installing one in this cabinet just to double check that this is an issue with your board. Please feel free to contact us again if you have any questions after trying these initial troubleshooting steps.
