help to find cocktail mode on ms pacman
Question from Rodrigo: hi my name is rodrigo and i fan of your videos on youtube, i am working on converting one ladybug cocktail table to ms pacman i get this pcb whit jamma conection i already did the jamma harnes but when i conect the pcb is on upright mode i tray the dip sw but no one work to switch the mode the pcb is a copy dosn’t have any brand only this numbers DS-M87052 i search in internet but whit exeption of one forum on klov.com this guy was saleing this pcb and one member ask if is pocible to put on cocktail mode and some one else say yes but no more than yes i try to contact this guy but no one respond this forum was old back on 2011 ,may be that is why they didn’t respond i now it need a jumper from the edge conection to some component but i don’t now which one if you can tell me will be fantastic i attach one photo to the board hopeing you can help me i will apreciate so much Thank you
Jonathan Leung Jonathan Leung ⋅ Staff August 19, 2013
Response from Jonathan: Rodrigo,
First off, thank you for watching our YouTube videos. If you’re interested in learning even more about arcade repair, you might read some of the posts on our web site and listen to our podcasts. You can find all of this content at arcaderepairtips.com.
As for your question, in order to put a Ms. Pac Man board in cocktail mode you must ground pin 14 on the parts side. In other words, you need to take the wire that’s coming out of the pin 14 hole on your harness on the parts side of the board (the side with all of the chips on it) and run it to a ground such as a metal plate or the floor ground coming from the power plug. Once you do that it should play in cocktail mode.
