HI THERE PLEASE HELP
Question from Nick: HI THERE I BROUGHT YOUR DVD’S AND ALSO WATCH YOUTUBE.. ONE QUESTION I HAVE IS ON THE JAMMA HARNESS HOW CAN YOU WIRE UP 6 BUTTONS FOR STREET FIGHTER VS XMEN. AND ALSO WIRE UP BUTTONS FOR PINBALL GAMES IF YOU CAN EXPLAIN OR DO A VIDEO ON IT WOULD REALLY HELP CHEERS…. NICK FROM AUSTRALIA
Response from Jonathan: Nick,
X-Men Vs Street Fighter is a Capcom CPS-2 game. All CPS-2 games require a JAMMA harness and a kick harness to wire all of the buttons up. The manual will tell you the exact location for each wire coming from each of the harnesses. Here’s a link to the manual in case you don’t have one already: http://pdf.textfiles.com/manuals/ARCADE/S-Z/X-Men%20vs.%20Street%20Fighter%20%5BOperator’s%5D%20%5BEnglish%5D.pdf. It’s probably a good idea to go back and read our posts and videos on Getting Familiar With The JAMMA Standard and Wiring An Arcade Cabinet Using The JAMMA Standard. These videos discuss in detail working with the JAMMA standard to wire up a game. Also, if you need a CPS-2 kick harness you can usually find one on eBay by doing a search.
Are you talking about the flipper buttons? These are the only buttons that I can think of that are found on pinball machines. If this is the case, it just depends on the pinball machine. Just like with the X-Men Vs Street Fighter, the best place to start is to get a manual for the pinball machine you are trying to repair. There should be a schematic and/or wiring diagram inside the manual that will tell you where the flipper buttons need to be wired in order to make them work. Once they are wired to the correct spot they should work unless there are other issues (such as power issues) with your machine.
