i have monitor troubles
Question from Dan: My screen plays blind with no sound its an virtua fighter 1 machine and i want to know how to fix it ive check every thing all that comes up is a line at the top please help
Jonathan Leung Jonathan Leung ⋅ Staff August 12, 2013
Response from Jonathan: Dan,
We always recommend starting at power with these types of issues. Make sure your monitor is getting the correct voltage from either the wall or the isolation transformer. You can check this by using a multimeter. You might also want to make sure that the fuse on the monitor chassis is in tact. This is another issue you can test with your multimeter using the continuity test. Of course, make sure the wiring going from your Virtua Fighter board to your monitor is making a good connection as well.
Once you’ve verified that everything above is working properly, you can proceed to the monitor chassis. It might be good to start with a cap kit first. If that does not solve your issue, check out our post on Troubleshooting Games That Are Playing Blind for more information about your particular issue. Now, once you get to this point you also have the option to send your monitor chassis off for repair. Check out our resources page under the Monitor Repair Services & Information heading for a list of people that you can repair your monitor chassis.
