Magnets and CRTs
Question from Scott: I have read some stuff in the past about putting speakers near a CRT, is a no no? Is that true? Can it permanently damage the CRT due to the magnetic fields? Those speakers are small, so I cant believe that could do anything. I have an NEC XM29 for instance (do you know what those are?), and have two little dell powered speakers on top of it. Just wondering if they can cause problems.
Jonathan Leung Jonathan Leung ⋅ Staff August 13, 2015
Yes, it is a good idea to keep speakers away from CRT monitors if you can. Putting the speakers close to a CRT shouldn’t permanently damage the monitor but they might (keyword MIGHT) cause some magnetic fields which will play havoc with your monitor’s picture. Leaving speakers close to a CRT monitor for extended periods can cause the shadow mask of the monitor to become magnetized which will can affect your monitor’s picture even after the speakers have been removed. The good news is that this will usually go away after a certain amount of time once the tube is no longer exposed to the speakers. Of course, a degaussing coil can take care of most of this picture issue that correspond to magnets and speakers. Your monitor should also have it’s own degaussing coil built in that will help demagnetize the shadow mask and clear up the discoloration issues with your picture. Hope that helps.
