midway touchscreen.
Question from Johnny: hi guys, im having a vet collapse issue with monitor i think. ive bought two chassis and it has the same problem. the picture is there but its small and twisted on both chassis. were do i start to look. the game was fine before i moved it to other wall in dining room over the carpet. Please help. thanks johnny.
Response from Jonathan: Johnny,
As we talked about in our post on Repairing Monitor Collapse Issues, monitor collapse is often the fault of a bad Horizontal Output Transistor (or HOT). You might try replacing the HOT on both these monitors to see if it helps your collapse issues. You might also have an issue with your horizontal width coil or with the polypropylene capacitors. Of course, this really depends on the type of collapse or how bad the collapse is. If you need further help, you might send us a picture of your monitor as that would help us better identify the issues you are having.
