Monitor issue
Question from Patrick: Hey Guys. I just bought a multicade at auction. It worked fine as of last night. At some point this morning, the picture was lost. I’m still getting sound just no pic. Where should I start? Thank you for any and all help. Patrick
Jonathan Leung Jonathan Leung Staff July 14, 2016
Response from Jonathan: Patrick,
It sounds like you are having an issue in the high voltage section of your monitor chassis. We’ve seen cold/cracked solder joints on the high voltage line cause this problem. We would recommend starting off with that by removing the monitor chassis from the cabinet and seeing if you can find any solder joints that need to be touched up. In fact, you may just want to touch up all the solder just so you know that the connections are being made. It would also be a good idea to double check that your monitor chassis is getting power from your cabinet. You can check this with a multimeter pretty easily by setting it on the appropriate AC setting and placing the probes inside the connector that goes to your monitor chassis.
If you continue to have problems after checking these areas, the issue could be caused by the flyback itself or other parts on your monitor (Horizontal Output Transistor, resistors, capacitors, etc.). See our post on Troubleshooting Games That Are Playing Blind for more information. At this point, you will need to identify which monitor chassis you have in your cabinet. If you are having problems determining the brand/model of your chassis, you can compare it to the pictures on the What’s My Monitor page by Bob Roberts and hopefully you can find a match. Once you know that, we can better help you troubleshoot this issue.
