Monitor Issues
Question from Jason: Your website is a great help to the community thank you for your knowledge. I do however have an issue I am have a monitor with digital controls that after adjusting it to display properly when the power is turned off the next time it is turned on the monitors settings are all messed up again. It seems to pull the settings out of the recall option on startup and the recall settings are basically all wrong. How do I save new settings under recall or make it hold the settings I change when powered off.
Thanks
Jason
What is the brand and model of your monitor? You might check out the What’s My Monitor page on Bob Roberts site if you need some help identifying it. Thanks.
