Monitor Shadow Effect
Question from Dan: Hey. I love the site and watched a bunch of your videos for help in rebuilding a naomi cabinet. I’m sure you guys are incredibly busy and I understand if you don’t have a chance to respond to this email, but I am having an issue with my arcade monitor and was hoping that maybe there was a simple solution. The best I can describe the problem is that there is a shadow effect, where everything displayed on the screen is faintly reproduced to the immediate right of the image, making everything look sort of distorted. It does not seem to be a convergence issue, since everything lines up fine and the colors look ok, but there’s this blurry run-off from the images. I had been messing with the color levels and brightness when I first noticed (caused?) this, but have since adjusted them and the convergence in every possible way to no avail. I attached an image where it can most clearly be seen next to the letters and numbers. Any thoughts if you have a chance would be greatly appreciated.
Thanks again.
Dan
Response from Tim: Have you adjusted the contrast? It does look like a convergence issue. You might need another yoke. Have you tried another board?
