Monitor troubleshooting
Question from Allan: I have a frogger cocktail
When turned on monitor is fine you can see and play game but after 3 minutes the game begins to lighten up until all you see is a white monitor .
Any suggestions that may help
Thanks allan
Response from Jonathan: Allan,
It sounds like you might have an issue with your flyback. The flyback is located on your monitor board/chassis and has a wire coming out of it that attaches to a suction cup (anode) that goes to your monitor tube. We would try replacing this part to see if it solves the problem. We have a video exclusively on our Volume 2 DVD that talks about Checking And Replacing The Flyback. You might pick it up if you need addition help. You can purchase this DVD as well as our other two volumes from our online store.
