Neo Geo Arcade
Question from Chris: Hello, I have a Neo Geo 4 Slot arcade. My monitor lines and picture are bent at the top of the monitor. When I adjust the picture to the right or left, the lines and picture are perfect but if I put the picture in center of the screen the top picture and lines are bent. I would welcome any advice and it would be greatly appreciated. Also, when I say bent lines on top of the screen that’s when I’m in the monitor test mode with all the lines.
Jonathan Leung Jonathan Leung ⋅ Staff October 8, 2015
It sounds like your monitor might be having some sort of convergence issue. You might check out our post on Adjusting The Convergence Rings for some information on how to do minor adjustments to the convergence on your monitor. If the convergence rings don’t help then you might want to look at our post on Monitor Convergence Tips as you may need to make some adjustments to the yoke in order to get the lines to line up correctly. Please feel free to contact us again if you have any specific questions about either of these posts.
