New project questions
Question from Tyson: So i have an arcade that i bought it is called avengers it is by capcom i guess what my question is, is that since it is a vertical monitor set up if it would be possible to rewire it up as a jamma cabinet and put a multicade in that one so that it could have games like dig dug and pac man and galaga and such. you helped me a ton on my other rebuild so i hope you can help me here. thanks guys
Tyson
Jonathan Leung Jonathan Leung ⋅ Staff January 16, 2012
Response from Jonathan: Tyson,
Yes, it is definitely possible to rewire it as a JAMMA cabinet and put a multicade board in it. You will need a JAMMA harness and a multicade board both of which can be secured from our friend Nick at Jamma Parts (http://www.jammaparts.net). Since the Avengers harness is the same number of pins as a JAMMA harness, you could get some of the harness pins and rearrange the wires. We will warn you that this can get somewhat confusing and we find that it’s best to just use a new harness. Check out our post on Getting Familiar With The JAMMA Standard for more information. Thank you for your question and good luck with your future repairs.
