no_subject
Question from David: Hi guys, I was listening to some older podcasts and heard a couple times you mention that when you replace your power cord you could hookup the black and white either way and it would work. If you have covered this in a more recent podcast please forgive me for bringing it up. as you said it will work, however, it is very important to get the black and white wires correct. the reason is polarity. the black is the hot wire (live) and the white is the neutral (return). If wired incorrectly the cabinet switch would only stop the flow at the switch. Since the switch is usually wired first in a cabinet this means that any electrical surge or other problem could still damage your game. this also puts any fuses wired before the switch on the end of the circuit instead of at the beginning. if the game is turned off at the switch then this will completely eliminate those fuses from the circuit giving no protection in case of a surge. if the game is on then again the fuses are at the end of the circuit. any power issue would travel completly through the game and then finially to a fuse. Not the ideal situation. this also applies to monitor power, lighting, or any other a/c device. hope this is helpful. enjoy the show. God Bless. Be safe
David from Springfield, Missouri
p.s. a little example of what i am saying is the breaker outlet you find in bathrooms. older ones wired backwards would not trip if there was a problem. new ones don’t even provide power if wired backwards. polarity is very important in a/c wiring.
Jonathan Leung Jonathan Leung ⋅ Staff January 8, 2014
Response from Jonathan: David,
Thanks for listening to the podcast and sending us this email. We were not aware that wiring the AC backwards in a cabinet would bypass the fuses but it makes perfect sense after your explanation. We plan on reading and discussing your email on the next podcast so we can present this information to our listeners. Thanks again and good luck with your future repairs.
