no_subject
Question: I have Dynamo Cabinet that orignal was A Street Fighter Cab, But some one switched the game to namco classic volume 1, and it required the vertical screen , so they turned it 90 degrees and put a cap kit in it, the screen is dark and dim , it turned the brightness all the way up in the back by the flyback and it seems its still to dim
Response from Jonathan: Have you tried the other adjustments? There should also be some potentiometers directly on the monitor chassis or on a separate board that attaches to the chassis. Among these pots should be another brightness adjustment and a contrast adjustment. Try adjusting these pots and see if it makes your screen better. Check out our post on Adjusting An Arcade Monitor for more information. Hope that helps.
