Pac Man Multicade Issues
Response from Jonathan: Justin,
It sounds like there is no power getting to the 60-in-1 board. You might try removing the board from the harness and using a multimeter to see if you are getting your +5 VDC and +12 VDC voltages to the correct pins on the JAMMA side of the Pac Man Adapter.
Remember that the power supply that you wire into the cabinet needs to have a 120 VAC going to it which can be accomplished by simply plugging it into a power plug or splicing into wires in the cabinet that carry the 120 VAC such as the marquee light wires. Also, ATX power supplies like these usually have a power switch on them that you will need to turn on for it to work properly. Make sure you have plugged in one of the 4 pin power connectors from the ATX power supply to the Pac Man Adapter as well.
If you’re still having trouble, you might take some pictures of the inside of your cabinet and send them to us via email at questions@arcaderepairtips.com. These should help us troubleshoot your issue further. Hope that helps.
Thank you for your questions and good luck with your repairs.
