Police trainer
Question from Jason: Hello, I recently was given a Police Trainer arcade game. I downloaded the manual to calibrate the guns. They are off slightly and I’ve checked the LED thing inside the barrel to make sure it was straight (thanks podcast 22) but I need to find the test button. I’m not sure where that is on this game. Can you help me out. Thanks, Jason
First off, thanks for listening to the podcast. We’re glad that we we’re able to at least point you in the right direction. Also, we just released a new post on Troubleshooting Light Gun Issues that might help you out as well. Check it out and see if any of those suggestions help you solve your issue.
Let me add one more comment concerning your particular problem. Sometimes when people wire cabinets JAMMA they forget to wire up the test and service buttons. This could be the case with your particular cabinet since you are having trouble finding these buttons. In this case, you might need to run these wires and install these buttons yourself. We like to use a button mount like this one from eBay: http://www.ebay.com/itm/TEST-SWITCH-FOR-ARCADE-WITH-3-BUTTONS-AND-BRACKET-/400585074604?pt=LH_DefaultDomain_0&hash=item5d44bb27ac. Basically you install this bracket in your cabinet then run the test and service wires (along with some ground wires) from your JAMMA harness to these buttons. Once you do that, you should be able to enter the test mode and service credit the game with no problems. Make sure you review our posts/videos on the JAMMA wiring standard and the JAMMA pinouts themselves for more information.
