Power switch on a classic World Series cabinet
Question from John: I know this is a silly question, but is there a on / off with to these type of games? I am not sure if there is and would like to figure out how to power it on.
Response from Jonathan: John,
It really depends on the game. Most games do have a power switch but some do not. If the game does have a power switch, it will usually be located either on the top of the cabinet, around the bottom edge of the cabinet, or inside the coin door. After looking online, I haven’t seen any documentation that indicates that the Cinematronics World Series game has a power switch. It does have an interlock switch on the door but that’s all I see. Of course, you can remedy this a couple of ways. You can install a power switch which isn’t too hard to do but does require opening up that back of the cabinet and getting familiar with AC wiring. Basically you just wire up a switch between where the AC Hot comes into the cabinet from the wall and where it goes to the rest of the parts inside the cabinet. Something like this switch from Twisted Quarter should work great for this. Of course, you can also just put the game on an AC power strip that has a power switch and just turn it on when you want to power on the game. The choice is yours.
