Revolution X Power Supply
Question from Patrick: I have a Revolution X game with a bad power supply and I was wondering which power supply to replace it with? It says 5V 12amp on it but I have not found those power supplies online. Should I use a 10 amp or 15 amp power supply? Thank you for your time, Patrick
Response from Jonathan: Patrick,
As long as the amperage that your new power supply outputs on the 5 VDC line is EQUAL TO OR HIGHER than what your current power supply outputs you should be in good shape. In other words, a power supply that outputs 15 amps on the 5 VDC line should work fine. Hope that helps.
