Smoked plexiglass on a cocktail cabinet
Question from Dave: Hi, I just watched your video on opening a cocktail cabinet (https://www.youtube.com/watch?v=jw7SOnPtYq4). This was very helpful, so thanks! After you took the glass off, you showed there was smoked plexiglass on top of the monitor. I have a new reproduction cocktail cabinet and it doesn’t have this. Could you explain it a bit more? Does the smoked plexi sit on top of the monitor bezel? Is the glass itself smoked, too, or is it completely clear? Thanks! Dave
Jonathan Leung Jonathan Leung ⋅ Staff January 28, 2015
Response from Jonathan: Dave,
The smoked plexiglass is mostly used on older cocktail cabinets that have CRT (or Cathode Ray Tube) monitors in them. The smoked plexiglass is usually attached to a frame that mounts directly to the monitor brackets. The main reason for the smoked plexiglass is to cover up the effects of screen burn on the monitor. As you may know, when the same image is displayed on a CRT monitor for a long period of time it tends to leave an impression in the tube itself. This impression is known as screen burn. This problem was particularly prevalent in games such as Pac Man so the manufacturer would install the smoked plexiglass to darken the monitor area which would “hide” the screen burn on the tube. Usually the cocktail glass itself is clear but may have some artwork painted on it similar to a bezel in an upright arcade game. Hope that helps.
