Space Invaders
Question: I have a Space Invaders arcade game and it has a loud buzzing noise you can hear a little of the games normal noises but the buzzing is way loud I unhooked the speaker any idea what is going on I assume the amp has a few bad capacitors? Thanks
Response from Jonathan: One thing to remember is that Space Invaders does not have a common amplifier like most games. With that said, it still could be some bad capacitors causing your issue.
You might check out this post on repairing Space Invaders sound issues:
http://www.brentradio.com/images/SpaceInvaders/si_sound.htm
It has some great information that should be able to help you out. Thank you for your question and good luck with your repair.
