Spots on monitor
Question from Jimmy: I’m not sure what is causing this,can you look at the pics of my monitor and tell me what you think would fix this. Is this something a cap kit would fix or is it the monitor. It has spots on the monitor.
Response from Tim: Lets start simple….have you cleaned the screen? Looks like it could just be dirt or somthing on the screen itself? if so then I am a little puzzled. Try unplugging your board and just bring up a white screen do you still see the dots then? If so then its your tube if not must be a board issue
hope that helps
