strang issue
Question from Michael: I bought a Commando arcade game. It seems every thing works right except when you try to play two players it will allow you to move around the first player but then when you die and the 2nd player loads you cant move him at all. Any help would be great also how do i know where to change the settings for free play off and difficulty. Thank you.
Response from Jonathan: Michael,
I didn’t know if you saw the reply on the Facebook page or not but I thought I would email you as well. Sounds like you need to adjust some of your dip switches on your game. I would imagine that since the 1 player joystick is not working on the 2 player game that you probably need to flip the cocktail table/upright switch to upright. Free play and difficulty can also be adjusted through these switches.
Check out the manual for Commando at http://www.crazykong.com/manuals/Commando.man.pdf. This should give you all the information you need to solve your issues. We will also be featuring your question on episode 12 of the podcast. Please listen to it for more thoughts on your issue. Thanks for your question and good luck making these adjustments.
