Test switch
Question: I have a jamma street fighter 2 arcade and it doesn’t have a test switch. I am trying to change the the difficulty of the game. Can you show me how to wire a test switch or shoot a video on the subject? Also can jamma boards be swapped out like plug and play? Or would there need to be some re wiring? Thanks for the videos I’m a subscriber and have learned a lot.
Response from Jonathan: Yes, we will be shooting a video on wiring test switches at some point in the future; however, you do not need the test switch to set the difficulty on a Street Fighter 2 board. There are 2 two sets of dip switches on the board that help you modify the settings of the game. The second set of switches (Dip B) controls the difficulty. Check out these settings for your game: http://www.arcade-museum.com/dipswitch-settings/9811.html. You can also check out our post on Adjusting Dip Switch Settings On A Board for more information.
As for swapping out JAMMA boards, we have a great post that should help you out with that. Here’s the link: http://www.arcaderepairtips.com/2011/08/31/swapping-boards-in-a-jamma-cabinet/. Hope that helps.
