Varcade Entertainment – Website E-mail
Question from Matthew: I have a Mortal Kombat 3 Jamma Board that is in need of some (minor) repair. Specifically, while attempting to connect the board to the (5 and 12 volt) power supply, I accidentally forgot to turn down the power first, before connecting the board. As a result, one of the small circuits on the board burned/melted. Is this something that you guys could fix, and, if so, how much would something like this run? If you have a chance, please let me know. Thank you, Matthew
Response from Jonathan: Matthew,
Unfortunately we are only doing local repairs at the moment. You might try our friend Raymond at arcadecomponents.com to see if he might be willing to fix your board. There is also a list of board repair guys at http://www.arcaderepairtips.com/resources/ under the Board (PCB) Repair & Component Sales heading that might be able to help you out. Thanks and good luck getting your board repaired.
