Vertical ic chip
Question from Craig: I’ve a vertical issue on monitor going to replace capacitors around ic .
I’ve found a replacement ic (LA-7838)but after that number there is another number. (7v9) do you now what that indicates
Response from Jonathan: I’m not exactly sure but I know that the last line on most chips has to do with the date code (i.e. date of manufacture) or other coded information. As long as the part numbers match you should be fine. Hope that helps.
