Viewer Question – Volume Control
Question from Corry: Hi guys, I’ve enjoyed catching up on a lot of your video series episodes the last month or so as I’ve been building a bartop MAME (based on RaspberryPi) and restoring a full size cabinet and turning it into a 60-in-1. For my full size cabinet, I’m turning a Make Trax cabinet into a 60-in-1. I’m currently using the JAMMA speaker connection (not the 1/8″ jack on the PCB) which is connected to a 6×9 speaker in the cabinet. I’d really like to get a volume control in-line. I tired adding multiple pot’s between 200K ohm to 1M ohm. They’re all way to sensitive – meaning turning the pot an extremely small amount changes the volume dramatically instead of a slower ramp down. Any ideas how to add a volume control like this? Thanks, Corry
Jonathan Leung Jonathan Leung Staff October 13, 2015
Response from Jonathan: Corry,
It sounds like the pots you have been using are too high in value. Try a lower value pot (like a 5K or 10K) instead and see if it works better. You can get these pots from Bob Roberts at http://www.therealbobroberts.net. Visit the parts page and do a search for “Volume Pot” and you should find what you are looking for. Of course, you should be able to get a lower value pot from the parts supplier who sold you the other pots as well.
Also, here is a link to a volume pot wiring diagram just so you can compare your wiring to it as a double check: http://scarvell.net/wiki/images/3/37/Vol_Pot_Wiring.jpg. It sounds like you have been wiring it up properly but it’s always good to check it again just in case.
