Winding Heat screen come on then goes off
Question from David: Hi Tim, your YouTube clips have helped me out a lot when fixing my machines. I live in South Australia and at the moment I’ve got a twin driver game winding heat made by Konami which has me screwed.
The game on start up both monitors go through there start up process, the right hand side has no problem and works fine. The left hand side gets to the demo and then screen goes black and is playing blind.
Any tips on this would make my day. Cheers. Kind regards, David
Jonathan Leung Jonathan Leung Staff March 24, 2016
Response from Jonathan: David,
It sounds like your monitor is experiencing some sort of voltage issue. This can be caused by the B+ voltage adjustment being too low on the monitor chassis. You might try adjusting this to see if it makes a difference in your issue. We also recommend installing a cap kit as bad filter caps in the power supply section can also cause this problem. Check out our post on Installing A Cap Kit for more information. If you need additional help, let us know the brand/model of your monitor chassis and we’ll try to help you out further.
